Toellner TOE 7725
The Toellner TOE 7725 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Toellner TOE 7725:
The frequency range of the Toellner TOE 7725 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Toellner TOE 7725.
Be careful changing these settings as RadiMation® is no longer able to verify if the Toellner TOE 7725 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
