UI.Graphs.AllowGraphSpecificCustomizations
An advanced option variable with the name UI.Graphs.AllowGraphSpecificCustomizations is available. By default its value is 'False'. However if the value is changed to 'True', the right-click menu on the graphs is made available. The right-click menu can be used to manually change the look and feel of the graph.
| Warning: | Any changes made to the look of the graph will not be remembered by RadiMation, and RadiMation will not recreate the style that was set if the graph is closed and opened again. Also any another event that triggers an update of the graph, could cause that the graph is resetted to the predefined RadiMation look again. |
This option is only implemented to allow certain customers to format a graph in the way they want to report it.
Also see:
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
