VZL 6941 Coupler
The VZL 6941 Coupler device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the VZL 6941 Coupler:
The frequency range of the VZL 6941 Coupler as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the VZL 6941 Coupler.
Be careful changing these settings as RadiMation® is no longer able to verify if the VZL 6941 Coupler is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
