Varian VZC6963G5 (Alenia Range 9)
The Varian VZC6963G5 (Alenia Range 9) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZC6963G5 (Alenia Range 9):
The frequency range of the Varian VZC6963G5 (Alenia Range 9) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Varian VZC6963G5 (Alenia Range 9).
Be careful changing these settings as RadiMation® is no longer able to verify if the Varian VZC6963G5 (Alenia Range 9) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Varian VZC6963G5 (Alenia Range 9)
- Google image search: Varian VZC6963G5 (Alenia Range 9)
