Varian VZC6963G5 (ELASIS)
The Varian VZC6963G5 (ELASIS) device driver is a Amplifier, Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZC6963G5 (ELASIS):
The frequency range of the Varian VZC6963G5 (ELASIS) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Varian VZC6963G5 (ELASIS).
Be careful changing these settings as RadiMation® is no longer able to verify if the Varian VZC6963G5 (ELASIS) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Varian VZC6963G5 (ELASIS)
- Google image search: Varian VZC6963G5 (ELASIS)
