Varian VZL6943G51574
The Varian VZL6943G51574 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Varian VZL6943G51574:
The frequency range of the Varian VZL6943G51574 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Varian VZL6943G51574.
Be careful changing these settings as RadiMation® is no longer able to verify if the Varian VZL6943G51574 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
