Virtual Absorbing Clamp
The Virtual Absorbing Clamp device driver is a Absorbing Clamp which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Absorbing Clamp:
The frequency range of the Virtual Absorbing Clamp as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Virtual Absorbing Clamp.
Be careful changing these settings as RadiMation® is no longer able to verify if the Virtual Absorbing Clamp is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Virtual Absorbing Clamp
- Google image search: Virtual Absorbing Clamp
