Virtual Antenna
The Virtual Antenna device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Antenna:
The frequency range of the Virtual Antenna as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Virtual Antenna.
Be careful changing these settings as RadiMation® is no longer able to verify if the Virtual Antenna is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Virtual Antenna
- Google image search: Virtual Antenna
