Virtual Calibration Jig
The Virtual Calibration Jig device driver is a Calibration Jig which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Calibration Jig:
The frequency range of the Virtual Calibration Jig as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Virtual Calibration Jig.
Be careful changing these settings as RadiMation® is no longer able to verify if the Virtual Calibration Jig is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Virtual Calibration Jig
- Google image search: Virtual Calibration Jig
