Virtual Multimeter as receiver
The Virtual Multimeter as receiver device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Multimeter as receiver:
The frequency range of the Virtual Multimeter as receiver as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Virtual Multimeter as receiver.
Be careful changing these settings as RadiMation® is no longer able to verify if the Virtual Multimeter as receiver is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Virtual Multimeter as receiver
- Google image search: Virtual Multimeter as receiver
