Virtual Network Analyser
The Virtual Network Analyser device driver is a Network Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Network Analyser:
The frequency range of the Virtual Network Analyser as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Virtual Network Analyser.
Be careful changing these settings as RadiMation® is no longer able to verify if the Virtual Network Analyser is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Virtual Network Analyser
- Google image search: Virtual Network Analyser
