Virtual Receiver (Heliview)
The Virtual Receiver (Heliview) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Receiver (Heliview):
The frequency range of the Virtual Receiver (Heliview) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Virtual Receiver (Heliview).
Be careful changing these settings as RadiMation® is no longer able to verify if the Virtual Receiver (Heliview) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Virtual Receiver (Heliview)
- Google image search: Virtual Receiver (Heliview)
