Virtual Signal Generator
The Virtual Signal Generator device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Virtual Signal Generator:
The frequency range of the Virtual Signal Generator as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Virtual Signal Generator.
Be careful changing these settings as RadiMation® is no longer able to verify if the Virtual Signal Generator is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Virtual Signal Generator
- Google image search: Virtual Signal Generator
