Wavecontrol SMP2
The Wavecontrol SMP2 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Wavecontrol SMP2:
| The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable. |
| If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop. |
The frequency range of the Wavecontrol SMP2 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Wavecontrol SMP2.
Be careful changing these settings as RadiMation® is no longer able to verify if the Wavecontrol SMP2 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The SMP2 can be connected to the PC by a USB cable, or a fibre optic cable.
When only a USB cable is used, the RS232 communication settings should be set to 115200 baud, 8 bits, no parity, 1 stopbit.
When the fibre optic cable is used, the RS232 communication settings should be set to: 230400 Baud, 8 bits, no parity, 1 stopbit.
