Werlatone Inc. C10762
The Werlatone Inc. C10762 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Werlatone Inc. C10762:
The frequency range of the Werlatone Inc. C10762 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Werlatone Inc. C10762.
Be careful changing these settings as RadiMation® is no longer able to verify if the Werlatone Inc. C10762 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
