Wiltron 6763A
The Wiltron 6763A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Wiltron 6763A:
The frequency range of the Wiltron 6763A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Wiltron 6763A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Wiltron 6763A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
