1M Ohm
Jump to: navigation, search
The 1M Ohm device driver is a Resistor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the 1M Ohm:
The frequency range of the 1M Ohm as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the 1M Ohm.
Be careful changing these setting as RadiMation® is no longer able to verify if the 1M Ohm is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
