1 Ohm
The 1 Ohm device driver is a Resistor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the 1 Ohm:
The frequency range of the 1 Ohm as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the 1 Ohm.
Be careful changing these setting as RadiMation® is no longer able to verify if the 1 Ohm is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
