A-INFO DS-3100 C
Jump to: navigation, search
The A-INFO DS-3100 C device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the A-INFO DS-3100 C:
The frequency range of the A-INFO DS-3100 C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the A-INFO DS-3100 C.
Be careful changing these setting as RadiMation® is no longer able to verify if the A-INFO DS-3100 C is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
