A-INFO Inc LB-OH-650-10-C-SF Octave Horn
The A-INFO Inc LB-OH-650-10-C-SF Octave Horn device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the A-INFO Inc LB-OH-650-10-C-SF Octave Horn:
The frequency range of the A-INFO Inc LB-OH-650-10-C-SF Octave Horn as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the A-INFO Inc LB-OH-650-10-C-SF Octave Horn.
Be careful changing these setting as RadiMation® is no longer able to verify if the A-INFO Inc LB-OH-650-10-C-SF Octave Horn is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: A-INFO Inc LB-OH-650-10-C-SF Octave Horn
- Google image search: A-INFO Inc LB-OH-650-10-C-SF Octave Horn
