AFJ LT-100
Jump to: navigation, search
The AFJ LT-100 device driver is a LISN which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the AFJ LT-100:
The frequency range of the AFJ LT-100 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the AFJ LT-100.
Be careful changing these setting as RadiMation® is no longer able to verify if the AFJ LT-100 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
