ARA Antenna Research DRG-118
The ARA Antenna Research DRG-118 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ARA Antenna Research DRG-118:
The frequency range of the ARA Antenna Research DRG-118 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the ARA Antenna Research DRG-118.
Be careful changing these setting as RadiMation® is no longer able to verify if the ARA Antenna Research DRG-118 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: ARA Antenna Research DRG-118
- Google image search: ARA Antenna Research DRG-118
