ARA LPB-2513
Jump to: navigation, search
The ARA LPB-2513 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ARA LPB-2513:
The frequency range of the ARA LPB-2513 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the ARA LPB-2513.
Be careful changing these setting as RadiMation® is no longer able to verify if the ARA LPB-2513 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
