Aaronia BicoLOG 20300
Jump to: navigation, search
The Aaronia BicoLOG 20300 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia BicoLOG 20300:
The frequency range of the Aaronia BicoLOG 20300 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aaronia BicoLOG 20300.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aaronia BicoLOG 20300 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
