Aaronia BicoLOG 30100E
The Aaronia BicoLOG 30100E device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia BicoLOG 30100E:
The frequency range of the Aaronia BicoLOG 30100E as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aaronia BicoLOG 30100E.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aaronia BicoLOG 30100E is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Aaronia BicoLOG 30100E
- Google image search: Aaronia BicoLOG 30100E
