Aaronia BicoLOG XL
Jump to: navigation, search
The Aaronia BicoLOG XL device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia BicoLOG XL:
The frequency range of the Aaronia BicoLOG XL as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aaronia BicoLOG XL.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aaronia BicoLOG XL is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
