Aaronia HyperLOG 20300 EMI
Jump to: navigation, search
The Aaronia HyperLOG 20300 EMI device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia HyperLOG 20300 EMI:
The frequency range of the Aaronia HyperLOG 20300 EMI as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aaronia HyperLOG 20300 EMI.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aaronia HyperLOG 20300 EMI is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
