Aaronia HyperLOG 4025
The Aaronia HyperLOG 4025 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia HyperLOG 4025:
The frequency range of the Aaronia HyperLOG 4025 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aaronia HyperLOG 4025.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aaronia HyperLOG 4025 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Aaronia HyperLOG 4025
- Google image search: Aaronia HyperLOG 4025
