Aaronia OmniLOG 90200
The Aaronia OmniLOG 90200 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia OmniLOG 90200:
The frequency range of the Aaronia OmniLOG 90200 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aaronia OmniLOG 90200.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aaronia OmniLOG 90200 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Aaronia OmniLOG 90200
- Google image search: Aaronia OmniLOG 90200
