Aaronia Spectran Emulated
Jump to: navigation, search
The Aaronia Spectran Emulated device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia Spectran Emulated:
The frequency range of the Aaronia Spectran Emulated as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aaronia Spectran Emulated.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aaronia Spectran Emulated is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
