Aaronia Spectran HF-80200 X
Jump to: navigation, search
The Aaronia Spectran HF-80200 X device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia Spectran HF-80200 X:
The frequency range of the Aaronia Spectran HF-80200 X as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aaronia Spectran HF-80200 X.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aaronia Spectran HF-80200 X is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
