Advantest R3361B
The Advantest R3361B device driver is a Power Meter, Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Advantest R3361B:
The frequency range of the Advantest R3361B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Advantest R3361B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Advantest R3361B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Advantest R3361B
- Google image search: Advantest R3361B
