Advantest TR4133 (10E3 to 3.6E9 Hz)
Jump to: navigation, search
The Advantest TR4133 (10E3 to 3.6E9 Hz) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Advantest TR4133 (10E3 to 3.6E9 Hz):
The frequency range of the Advantest TR4133 (10E3 to 3.6E9 Hz) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Advantest TR4133 (10E3 to 3.6E9 Hz).
Be careful changing these setting as RadiMation® is no longer able to verify if the Advantest TR4133 (10E3 to 3.6E9 Hz) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
