Advantest TR4172
Jump to: navigation, search
The Advantest TR4172 device driver is a Signal GeneratorPower MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Advantest TR4172:
The frequency range of the Advantest TR4172 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Advantest TR4172.
Be careful changing these setting as RadiMation® is no longer able to verify if the Advantest TR4172 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
