Aeroflex 2023
The Aeroflex 2023 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aeroflex 2023:
The frequency range of the Aeroflex 2023 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Aeroflex 2023.
Be careful changing these setting as RadiMation® is no longer able to verify if the Aeroflex 2023 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Aeroflex 2023
- Google image search: Aeroflex 2023
