Agilent 87405B
The Agilent 87405B device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent 87405B:
The frequency range of the Agilent 87405B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent 87405B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent 87405B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Agilent 87405B
- Google image search: Agilent 87405B
