Agilent 87405C
Jump to: navigation, search
The Agilent 87405C device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent 87405C:
The frequency range of the Agilent 87405C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent 87405C.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent 87405C is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
