Agilent Technologies 33220A
The Agilent Technologies 33220A device driver is a Signal Generator, Modulation Source which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies 33220A:
The frequency range of the Agilent Technologies 33220A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent Technologies 33220A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent Technologies 33220A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Agilent Technologies 33220A
- Google image search: Agilent Technologies 33220A
