Agilent Technologies 4440A
The Agilent Technologies 4440A device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies 4440A:
The frequency range of the Agilent Technologies 4440A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent Technologies 4440A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent Technologies 4440A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Agilent Technologies 4440A
- Google image search: Agilent Technologies 4440A
Manuals
The programming manual can be found here
