Agilent Technologies E4403B (EMV GMBH)
The Agilent Technologies E4403B (EMV GMBH) device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies E4403B (EMV GMBH):
The frequency range of the Agilent Technologies E4403B (EMV GMBH) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent Technologies E4403B (EMV GMBH).
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent Technologies E4403B (EMV GMBH) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Agilent Technologies E4403B (EMV GMBH)
- Google image search: Agilent Technologies E4403B (EMV GMBH)
