Agilent Technologies E4440A
Jump to: navigation, search
The Agilent Technologies E4440A device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies E4440A:
The frequency range of the Agilent Technologies E4440A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent Technologies E4440A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent Technologies E4440A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
