Agilent Technologies N1911A Channel A
Jump to: navigation, search
The Agilent Technologies N1911A Channel A device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies N1911A Channel A:
The frequency range of the Agilent Technologies N1911A Channel A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent Technologies N1911A Channel A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent Technologies N1911A Channel A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
