Agilent Technologies N1913A
Jump to: navigation, search
The Agilent Technologies N1913A device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies N1913A:
The frequency range of the Agilent Technologies N1913A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent Technologies N1913A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent Technologies N1913A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
