Ailtech PN 96001
The Ailtech PN 96001 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ailtech PN 96001:
The frequency range of the Ailtech PN 96001 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Ailtech PN 96001.
Be careful changing these setting as RadiMation® is no longer able to verify if the Ailtech PN 96001 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Ailtech PN 96001
- Google image search: Ailtech PN 96001
