Amplifier Research 10000A250A
Jump to: navigation, search
The Amplifier Research 10000A250A device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 10000A250A:
The frequency range of the Amplifier Research 10000A250A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research 10000A250A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research 10000A250A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
