Amplifier Research 250L (CP3000 controlled)
Jump to: navigation, search
The Amplifier Research 250L (CP3000 controlled) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 250L (CP3000 controlled):
The frequency range of the Amplifier Research 250L (CP3000 controlled) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research 250L (CP3000 controlled).
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research 250L (CP3000 controlled) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
