Amplifier Research 500W1000A (Wildmoser)
Jump to: navigation, search
The Amplifier Research 500W1000A (Wildmoser) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 500W1000A (Wildmoser):
The frequency range of the Amplifier Research 500W1000A (Wildmoser) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research 500W1000A (Wildmoser).
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research 500W1000A (Wildmoser) is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
