Amplifier Research 500W1000 Series Forward
Jump to: navigation, search
The Amplifier Research 500W1000 Series Forward device driver is a Power Meter which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 500W1000 Series Forward:
The frequency range of the Amplifier Research 500W1000 Series Forward as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research 500W1000 Series Forward.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research 500W1000 Series Forward is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
