Amplifier Research ATL80M1G
Jump to: navigation, search
The Amplifier Research ATL80M1G device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research ATL80M1G:
The frequency range of the Amplifier Research ATL80M1G as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research ATL80M1G.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research ATL80M1G is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
ScreenElementDescription.png Efficiency The antenna efficiency factor of the antenna.
