Amplifier Research DC4000
The Amplifier Research DC4000 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research DC4000:
The frequency range of the Amplifier Research DC4000 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research DC4000.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research DC4000 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Amplifier Research DC4000
- Google image search: Amplifier Research DC4000
